pulpwood007's avatar
pulpwood007
Refrigerator cooling question
I have followed all the threads involving improving cooling on RV refrigerators. My Norcold is a constant problem to keep the temps at around 40 degrees.
My question is in regards to installing additional fans, both blowing across the coils and inside the fridge to circulate the air. There are controllers sold to only activate the fans when the refrigerator is running (in the cooling mode). They turn off after the cooling cycle is complete.
Other folks just simply install fans that blow across the coils, and circulate air inside the fridge and control them manually. Either leaving them running continuously or turning them on when the fridge will not maintain correct temps.
Are there any issues in letting the fans run continuously? Less efficiency?
