pulpwood007
Jun 04, 2020Explorer
Mitch,
Looks good. I like the kit, however just found a nice 12vdc controller with temp sensor on Amazon that's cheap. It simply turns on/off fans based on the temp range you set. By going with a stand alone controller like this I could use muffin fans or squirrel cage blowers and get the specs I want.
Exactly where did you place the sensor for your controller?
I also just found a system called the Fridge Defend by ARP that actually controls the fridge if it gets too hot, as well as fans, but it's a lot more expensive than a DIY fan system.
Chip
Chip
