hertfordnc
Apr 21, 2020Explorer
wolfe10 wrote:
Gel batteries are OK at a HIGHER voltage than wet cells. So, unless you are really over-charging the other bank (wet-cell or AGM), I don't see the issue.
Perhaps i'm missing something, it is my understanding that gels need to be smart-charged with a higher initial voltage of 14.5 or so falling to something lower at 80%
My power supply is a 40 amp WFCO converter which i believe will not be appropriate for the gels.
Meanwhile, i have a small smart charger that automatically switches to float after a certain charge lever.
Also, because i happen to have the gels i plan to put one of both in a void inside where they can be unvented. That takes 100 lb off the tongue and leaves the front battery box handy for tools or rags or beer.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
