landyacht318
Nov 04, 2015Explorer
I had opened mine up, flattened the aluminum heatsinks with a file and spooged on the thermal grease. I'd also put a 60x15MM wart on the outside of the case.
It still buzzed over 36 amps, and after saying 'Eff' it, I set it to 14.7v unloaded, and plugged it into a depleted battery.
Smoke and sparks at 17 minutes of buzzing.
My cheapowatt had ~90% thermal grease coverage between aluminum plate and casing, also on the thermal pad.
It blew after given some spit and polish with better heatsinking and increased airflow.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
