- wnjjExplorer II
John Wayne wrote:
Buy a Scan Gauge II read and clear your codes and get other information like trans temp. and more.
A $10 bluetooth OBD2 scanner + Android cellphone/tablet + "Torque" App = a scanner good enough for reading/clearing most codes. - ScottGNomadDon't just keep driving it that way. It can cost you.
- Tyler0215ExplorerThe check engine light means that something is wrong. Buy a code reader or find someplace that will read it for you. It could be a simple fix or a costly one, but get it checked out. Or electrical tape over the light.
- John_WayneExplorer IIBuy a Scan Gauge II read and clear your codes and get other information like trans temp. and more.
- amxpressExplorerMost auto parts stores, and WalMart, have the ability to retrieve codes. Should be able to find a lot you’re able to pull into.
- donn0128Explorer IIYes. As always it should be near the stearing column under the front edge of the dash.
- vandaveExplorerThanks for the replies. I doubt I can gat my Motor Home in the auto zone lot. Do new, class A MH with the V-10 have a port to hook diagnostics to?
- ScottGNomadAgree'd you need to read the code(s).
Could be as simple as a loose gas cap. - MitchF150Explorer IIICause you are supposed to get the code read and go from there... :)
Good luck!
Mitch - donn0128Explorer IIYou have a stored error code. Go to autozone and have then read it. With that code you can look up possible causes.
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
