NKnowland
May 09, 2021Explorer
ksg5000 wrote:
When on "auto" the fridge should resort to AC if it's available. If no AC then it will revert to gas and the Check Light will come on if the gas fails to ignite. If you select "gas" and your haven't turned on the propane and you don't get a "check light" then something maybe wrong - light bulb or maybe bad board.
If it were me I would turn on the gas - select gas and then see what happens. Make sure the gas lines are purged - (turn on the gas stove). If that works then I would plug in the RV to AC and select auto - and see what happens.
- Gas on, select Gas, then gas comes on.
- AC on, select Auto, then AC comes on.
- Gas off, select Auto, select Gas, NO check light comes on
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
Related Content
- Feb 01, 2026Community Alumni
