ocean_boundExplorer IIMay 27, 2015check valvethe check valve I replaced near water heater is making a humming sound when I turn on hot water any thing I can do to stop it from making noise
JPeytonExplorerMay 27, 2015It may just be resonating because of how tight it is. Might try and either loosen or tighten just a bit. Try opening the valve a few times also.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
Related Contentcheck valve!!Water Heater Check Valvecheck valveswater pump check valveWater pump check valve.
