If you use an adjustable pressure regulator you can try changing the pressure a little. It may eliminate or change the frequency so it isn't as objectionable. Or you can upgrade or remove the check valve as others have said.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
