Gjac's avatar
Gjac
Explorer III
Jul 20, 2013
Checking Battery SOC
I have 2 6v batteries that are not on slide out trays so for 8 years I have been checking with a volt meter. I wired the pos and neg with 2 wires that I can easily check from inside the MH. I have no room to fit my temp compensating bulb hydrometer to check above the batteries so I bought a WM short floating needle type which is only 6 ins long that I could fit in above the batteries. Which I use on occasion which always read 1.300 when the volt meter read 12.7v. I decided to test it with distilled water last week and it still read 1.300. I post this for others that have no room for a real hydrometer reading. Has anyone figured out a way to take readings without removing the batteries?
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 20, 2026
