dtappy3353's avatar
dtappy3353
checking exterior lights
What is the "thing" that plugs into the six pin pigtail that activates all the exterior lights on the trailer?
I would like to be able to check them before a trip without having to hook up the truck all the time. Lazy...yep!
Thank you.
  • select your connector diagram from here.wiring diagrams
    Use a short piece of wire to jumper between the lighting pins and the pin used for battery charge from the TV.
    This will test trailer wiring using the trailer battery.
    Remember that it does not guarantee lights work from the TV.
  • The exterior lights on the trailer operate off of the truck, not the trailer batteries. You need to plug in the truck to verify correct operation.
    Do you have issues with burned out bulbs? What are you trying to check before a trip? Most RVs use LEDs and have for a great many years. A burned out LED bulb is rare. I have never had one fail even after years and years of use.
Having RV issues? Connect with others who have been in your shoes.24,315 PostsLatest Activity: Sep 09, 2025
