HiTech
May 27, 2013Explorer
mena661 wrote:HiTech wrote:I know you didn't ask but I use a Victron battery monitor for voltage (does other stuff), it uses a shunt (like the Trimetric), and a Freas hydrometer which I understand to be pretty accurate.
12.78v predicted. Pretty close given likely error in hydrometer and volt meter. Even more so if it had settled slightly at 24 hours.
I'm using three shunt meters as well - a watts up and two turnigies. They are not quite as good because there is 3 inches of wire between the battery and shunt vs the cool on post shunt a lot of you use, but both seem pretty accurate. I desoldered the shunt on one of my watts up with too much transient current. I am thinking of getting a larger one and remote mounting it at the battery post. They have directions on how to do this on their web site.
Jim
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 31, 2025
