Splashers3's avatar
Splashers3
Tire Pressure Accuracy
When measuring my RV tire pressure I have the TST TPMS, but when checking my tires before each trip, I also use one of those pressure measuring "sticks" (the kind in which you push on the stem and the measurer pops out the bottom telling you what your pressure is). The stick is much easier to use when adding air and with the TST, I have to repeatedly screw on/off...you guys know what I mean.
My quantry - the two systems are about 7-8 pounds different (across each tire, 111/112 vs 104/5). Which system would you trust as being closer to the real tire pressure? My tires are 110 PSI rated. The stick is one of the bigger models, over a foot long, not sure if that means its better than a small style.
Thanks for your help,
Mike
