JoeH's avatar
JoeH
Explorer III
Jan 11, 2021
Checking voltage on LED power supply ?
Not RV related per se, but figured someone here would know. I recently purchased a set of LED lights to put some path lights to avoid tripping. Hooked up the lights and everything works fine.
Next, I decided to put a strip of 5050 led's on some stairs. The strip LED's have + and - markings and are 12v . The output from the power supply for the path lights is also 12v so I figured I'd hook into that. I got out the meter and I get nothing when I check the voltage, yet the lights work. Check the meter with a different power supply I have for some other lights and it reads 12v as it should. So, why would the new power supply indicate no voltage and yet at the same time, successfully light up the 12v LED lights?
  • JoeH's avatar
    JoeH
    Explorer III
    Gdetrailer wrote:
    JoeH wrote:
    Tom_M wrote:
    Switch your meter to AC and check. Most likely one supply is AC and the other is DC.
    Nope-- meter stays on "0" regardless of being on AC or DC.... but the LED lights out in the yard work. Strange
    Post a pix of the power supply with the model number..
    I suspect it is a high frequency switching supply and has no or little filtering on the output.. Most meters will not read at all or properly 15Khz-30khz frequencies which most switching supplies operate at which could explain why you can't get a reading but the lights work.
    I'll get a pic soon---- sounds like you might have solved it.
  • JoeH's avatar
    JoeH
    Explorer III
    Conformal coating.
    I didnt exactly understand your entire post but type that into Google.
  • Switch your meter to AC and check. Most likely one supply is AC and the other is DC.
  • Reverse your meter leads may show voltage.
    It could also be the way diodes are placed in the circuit.
