Old-Biscuit
Mar 25, 2014Explorer III
powderman426 wrote:badboy368 wrote:
i use the same in black and grey tanks
So do I. It's called water. Like said in a previous post " If everything is working properly there should be no odor inside.".
Exactly.......
If there is an odor from ANY waste tank inside the RV then something ain't right.
Either toilet floor flange or toilet bowl seal aren't good
'P' traps aren't holding water
Air Admittance Valves aren't closing
Tank vents are plugged/clogged
OR drain line to/vent line from tanks are cracked
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
