DryCamper11
Oct 03, 2013Explorer
j-d wrote:
By how much is it too thick?
I'll be able to check it tonight. It was hard to estimate and DW picked up the old rotor today from the shop for comparison.
MEX suggested having it turned to get it true anyhow.
It wasn't needed. At least, not for truing. I put a dial gauge on it and it was nearly perfect.
There was discussion about what made it thicker, the two "platters" that have the braking surface, or the "honeycomb" in between the platters? If there's more "meat" in the platters (same honeycomb thickness as the one your're replacing) then cutting them down a little should turn out OK.
That's my thought, too. It's why I've got the old one back - to compare more closely. The honeycomb looked the same - the platters looked thicker, but I'll be able to measure accurately with the old one in my hands.
What about what I'll call "offset" where I mean how the rotor ends up inside the caliper gap? The offset I'm thinking of could measure from the bearing race to the center of the honeycomb.
I don't remember what the coach was, but somebody on this forum had to take a new rotor that otherwise fit but the Diameter was too big. Had the edge machined off of it, reducing diameter by a fraction of an inch. I don't remember if it was 1/8 or 1/4 or as much as 1/2 (inch) but everything else was OK and it worked after.
The diameter is fine, but the "offset" is something I wonder about, also. I did a rough measurement of offset as compared to the opposite side, but again, it will be easier to get this measured with the old one in my hands.
I hate to ask another question, but is the face of the braking surface wide enough (from edge to hub) for your pads?
Yes. I didn't think to check, but tonight I'll see if the old pads will fit from other side. I won't use them, but it should tell me a bit about offset, as well.
You could of course machine the Pads down, but that wouldn't be my first choice. For no other reason, all of a sudden you need new pads during a trip. You don't want to be crouched on a concrete sidewalk trying to work'em down.
It looked like I'd need about 1/16" off the pads or inside surface of the rotor. Eventually the rotor will wear down to fit, but ....
If you weren't able to get the exact replacement rotor, then I'd say take your worn one and new one to an automotive machine shop and ask if they can make the New the same as Old started out.
I also suppose the later model chassis had a different caliper, but trying to find and install that could be another can of worms.
Yes. I've got a good shop that could handle it. That's where the brake rotor was when i started this. He called to say it wouldn't meet spec any more with the grooves machined off, and I figured I'd grab one at the local NAPA. Since then I've had trouble finding one anywhere for the '73.
