John wrote:
What is not clear is what psi is needed, wanted, or best; max or per load tables.
IMO this is where experience comes in.
CapriRacer makes a good point on taking advantage of a tires reserve capacity you IMO erroneously are calling a safety margin. There is no advantage of the D tire over a C tire at those severally reduced pressures.
This advice from Nitto tire I believe CapriRacer has brought to the forums attention previously. The tire types/pressures are different but the same scenario applies so pay close attention to the last sentence :
Load Comparison Example, P vs. LT:
"P265/75R16 114 Max Load = 2,601 lbs @ 35 PSI
In order to carry the equivalent load, a LT265/75R16 Load Range C must be inflated to 50 PSI. Using this
example, even LT265/75R16 Load Range D, or E must be inflated to 50 PSI to carry the P-metric load at
35 PSI.
LT tires do not offer any benefits of being "heavy duty" when under-inflated."
I have a single axle 3400 lb bass boat and a light weight 14" tandem axle lawn service type trailer with 2700 lb axles. I keep P tires on both of them. Speed limit on I-44 near me is 75 mph which I sometimes take advantage of when pulling either trailer.
