brulaz
Nov 29, 2017Explorer
If your solar charger has temp compensation, use that for the final 20% of charge. The first 80% or bulk charge doesn't really require temp compensation.
You can use an adjustable power supply to manually bulk, or the cheaper Prog. Dyn. to get the batteries up to 80%; then let it drop out and leave the temp compensated solar to finish it properly.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
