BFL13
Nov 29, 2017Explorer II
phemens wrote:MrWizard wrote:
1000w at 24v is not 100 amps
If you have a 100 amp controller? That's great, you are way within margin
Enjoy
I like large converters for fast generator recharge , and prefer solar for top off and carrying the daytime load
My preference would be the Power Max, adjustable converter
Set at 14.8v
Any reason to pick the PM4 series over the PM3?
You do not want either. They are not right for doing 50-90s from a generator off grid.( don't work for fast charging all the way to 90 --might drop to 13.8 at 75% eg) their charging profile is not right for that- either one.
However, you do want the Adjustable voltage model, which is usually a modified PM3, but that doesn't matter. It works for keeping your AGMs (or wets) proper. It is not hard to turn the knob to the correct voltage once in a while. :(
http://www.bestconverter.com/Boondocker-BPCM-75-75-Amp-Adjustable-Power-ConverterCharger_p_587.html#.Wh9oAFKWxLM
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
