Bend
Dec 03, 2014Explorer
Padlin-
Your Bogart Trimetric 2030 system is meant to optimize battery charging. It can produce charging voltages that are beyond most inverter high voltage cut-offs. The options are:
Sub-optimize the 2030 with a lower bulk/topping voltage.
Find a PSW inverter that does not turn off below 16v. Samlex PST series is one example.
Run the inverter only when solar is not charging (turned off or at night).
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 18, 2026
