dodge guy wrote:
So. I’ll be installing a 3000W inverter and with that, what is better? A 300A circuit breaker or an ANL fuse? I like the fuse so I don’t have to keep spare fuses, but a circuit breaker will be easier to just reset.
look at or estimate what the MAX short circuit current of your battery bank could be. Make sure whatever fuse or breaker you choose will interupt that current level.
When I did checking for my install of a 1000W inverter, ANL fuses worked, most reasonably sized, affordable, obtainable circuit breakers weren't spec'd for the battery bank short circuit current capability.
