Mike_Stanbro's avatar
Mike_Stanbro
Explorer II
Jan 04, 2014
Replacing fuses with circuit breakers for motor circuits
I recently purchased a Lance 855S truck camper. When I went to pick up my camper from the dealer, one of the 30 Amp fuses for the jack motors popped when the jack hit its upper limit. We didn't know that had happened, all we knew was that one jack quit responding to the remote control. After 30 minutes of trying this and that, the technician at the dealer thought to check the fuses on the control board and found the problem. I made a mental note to replace those fuses with circuit breakers as soon as possible.
Motors generate huge current demand when at stall which occurs whenever the mechanisms they power hit end-of-travel. Most jack and slide-out mechanisms have clutches that release at end-of-travel but if it is really cold they can be rather stiff and cause excessive current demand.
There are different types of breakers, auto-reset (Type 1) are the best for jack and slide-out circuits. Type 1 breakers open when there is excess current and then quickly reset when the overload is removed.
I got four 30A blade-style circuit breakers for the jack motors, and one 5A breaker for the slide-out motor at NAPA. These have the same blades as mini fuses so they will plug into existing fuse holders. In other words, quick and easy to install.
If you have a camper or trailer with powered jacks or slide-outs, do yourself a favor and replace any fuses with auto-reset circuit breaker. I had a 30A fuse for the front landing gear of my 12,000 pound 5th-wheel pop while camping in Death Valley. After I got it hand cranked onto my truck, I made a promise to myself to get rid of all fuses from motor circuits.
Here are URLs to 5A and 30A blade-style breakers at the NAPA website if you are interested:
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Circuit-Breaker-5-Amp-Blade/_/R-BK_7823010_0006522027
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Circuit-Breaker-30-Amp-Blade/_/R-BK_7823124_0361083750
