dsimonson's avatar
dsimonson
City Water is filling/overflowing my freshwater tank
I must have a check valve issue, because when I attached city water to my trailer, I noted that it started (slowly) filling up my freshwater tank to the point it overflowed.
I see that I can pretty easily replace the city water check valve, but I don't see where I can start looking for the other check valve - there must be one to prevent this from happening. Any ideas on where I should start looking? I have an APEX ULTRA-LITE - 249RBS.
Thanks!
Dan
Dan Simonson
  • wnjj's avatar
    wnjj
    Explorer II
    The check valve is part of the water pump itself. Try running some water through your system by using the pump. That may reseat it or let whatever debris through that may be making it leak. If that doesn’t work, it’s fairly simple to take the pump head apart to clean and inspect the diaphragm.
    If you are referring to the city check valve at the hose connection that is not the issue. That one prevents pump pressure from pushing water out of that connection when it’s not In use,
Having RV issues? Connect with others who have been in your shoes.24,228 PostsLatest Activity: Apr 04, 2025
