PCronin68's avatar
PCronin68
Class A AC Questions
I have a new 2014 Bounder 34b and have used it twice (FT Myers 7 day vaca and local weekend trip). It appears to me I have an AC issue. The unit seems to run a lot to keep or to get RV down to 72-75 degrees. I had the dealership check the temp sensors in rear and front and they are within manufacturer tolerance because first i thought they weren't reading correctly. I don't think they checked the technical workings of the thermostat. What I see is I cant get the rear (zone 2) to go on high fan whether thermostat is set to manual or high. I think the front AC is working extra hard because of this. Any thoughts?
1 Reply
  • How much the AC runs is dependent on your outside temperature and if you are parked in direct sun. In our 33C, if it is 95 degrees outside and we are parked in direct sun with our shades open, our two ACs will run nearly constantly to keep the temperature down at 75. The ACs will also cycle so as to not freeze up.
    We have found, when parked in direct sunlight and with outside temperatures at 75, the RV heats up quickly. To keep the temps down and the AC not running so much, park in the shade, pull down the shades, especially the front, open a vent in the roof to allow heat to escape, and crack a few windows to allow in a breeze.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 13, 2025
