garyemunson
Dec 02, 2016Explorer II
Technically, two six volt golf cart batteries wired in series are a much better solution than two twelve volts in parallel. The problem is that as the 12 volt batteries age, one ages faster than the other then starts appearing as a load for the better battery to charge when you are not plugged into shore power. Two six volts do not have this issue. It just adds up to more charge/discharge cycles the batteries have to go through....
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: May 23, 2026
