SoundGuy
Dec 02, 2016Explorer
garyemunson wrote:
Technically, two six volt golf cart batteries wired in series are a much better solution than two twelve volts in parallel. The problem is that as the 12 volt batteries age, one ages faster than the other then starts appearing as a load for the better battery to charge when you are not plugged into shore power.
If two new 12 volt batteries, manufactured around the same date, are wired in parallel and always drawn down together, why would one "age faster" than the other? Got a link to documentation that clearly supports this argument? :@
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
