MrWizard
Jun 06, 2016Moderator
You can 'Connect'' the solar into the wires that go from the battery to the power converter and DC fuse panel
Not as optimal as connecting directly at the battery , but it will work
There is a good possibility that the converter is near or under the fridge, access to the wiring should not be too difficult
Connecting up front under the hood would be the least desirable location
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
