klutchdust
Oct 04, 2015Explorer II
j-d wrote:
I'm pretty sure 5200 will hold it together if you were able to get clean surfaces. Please let us know how it turns out.
One thing is the adhesive takes a week to fully cure, not a problem. One man said that because it reacts to temperature he stores his
un-used in a zip lock bag in the freezer and lets it warm up if he needs to use it.I have a bracket that holds the awning support that comes loose and
I applied some to that as well. The holes are slightly larger than the fasteners so a little dab on those. Having the TV removed it gives me an opportunity
to look at some of the wooden framework that goes into building these coaches. I have found and tightened numerous fasteners and applied some good
old wood glue to certain areas . It all helps to keep the coach less troublesome quiet and dry.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
