Pete_k
May 06, 2022Explorer
Generator exhaust bracket.
Our 2016 Eagle Cap 1200. Had a banging sound when running the Generator. Found the rubber isolator exhaust bracket had broken. Looking online the replacement was $65. Being I will not pay that for a cheap part. Found a replacement for only $4.97
Used this mount.
Click For Full-Size Image.
Used the factory screws and top mounting holes. Worked perfect to mount this one back into its spot.
Then I loosened the clamp on the pipe itself. Twisted the rubber and bottom mount. Slid it up under the pipe clamp. Tightened that clamp back down. Job was done in under 5 minutes.
[img]
Click For Full-Size Image.[/img]
Used this mount.
[img]
