SM49's avatar
SM49
class c upper clearance lights
I have a 2004 Four Winds 28 class c, the upper front clearance lights don't work. no power to them, ground is good, all of them work if I feed power to the drivers side light, does anyone know where the wiring would run to feed these lights
  • They go in sections of pos wire around the top of the Rv. If one light in that section loses its pos wire connection the whole section goes but the other sections work. Pull each light in that section that does not work to find the "open".
  • Has the water resistance been inspected and repaired if necessary?
  • They are in the parking light circuit have you checked to see if your chassis parking lights work? If not, I would check the parking light fuse for beginners.
Having RV issues? Connect with others who have been in your shoes.24,240 PostsLatest Activity: May 04, 2025
