- MEXICOWANDERERExplorerBoiling hot water, a gallon mixed with half a big box of baking soda will clean multiple batteries and trays. Hardware stores sell inside copper tubing wire brushes that last longer than auto parts stuff.
If the terminal/post mating surfaces have a hard crystal-like black coating, they will have to be scraped off with a knife. The post and lug will have to end up shined to a bright silver color. - campinginthewooExplorerFrom Google
Directions:
1.Remove the battery cables from the battery terminals by loosening the nut on each cable clamp. Once they are loose, always remove the cable clamp from the negative terminal first. It’s marked with a minus (-) sign; the positive terminal has a plus (+) sign. Reverse the procedure, positive first, negative second, when replacing the cables. The cable may not come off easily. You will have to wiggle it and lift it upward until the clamp comes off the terminal post. Sometimes, especially if there is a lot of corrosion, you may need the assistance of pair of locking pliers. Be careful not to short any tools you use against the car when they’re in contact with the battery.
2.Examine the battery cables and clamps for excess wear or corrosion. Should damage appear extensive, replace the cables and clamps to avoid future problems.
3.Check the battery case for cracks and the terminals for damage. If you find either, replace the battery.
4.Secure the loose cables so that they don’t accidentally flop back onto the terminals.
5.Pour some baking soda directly onto the posts.
6.Dip a toothbrush in water and use it to scrub the baking soda into the terminal posts and cable clamps. Skin and eye protection is recommended.
7.If the toothbrush isn’t doing the job, Use a battery terminal cleaner brush on it. Also shine up the insides of the cable clamps by using the clamp cleaner that usually comes attached to the terminal brush or use a plain, soap-free steel wool pad.
8.Dry everything off with a clean, disposable, lint-free rag.
9.Smear grease or petroleum jelly on the posts to slow down the formation of corrosive deposits. Cover all exposed metal surfaces on the battery posts, battery cables, and clamps.
10.Replace the positive clamp first and then replace the negative clamp. Tighten them down with the proper sized wrench.
11.Replace the rubber boot or plastic shield that covers the positive terminal. If you don’t have one, go and buy some from your local auto parts store. - hersheyExplorerQuickest and easy way it to use a can of Coke. Remove the cables, and clean with a wire brush to remove the big lumps and then just use the Coke to remove the corrosion and bring them back to shinny new condition. Rinse with water if you like.
Of course baking soda is the best known, oldest cleaning agent. - Autoparts store has all the stuff you need along with a lot of water from the hose.
- KD4UPLExplorer IIThere are chemicals available specifically for the purpose. A good battery shop or auto parts store should have them. A wire brush helps to knock loose the corrosion. There are wire brushed available specifically shaped to fit inside the wire terminals and around the battery posts.
Vinegar works pretty good to clean up battery terminals. A mixture of backing soda and water can be used to neutralize the acid that may be on the terminals before cleaning them. Just be VERY carefully you don't let any get into the battery thru the caps or it will ruin it.
After you have the terminals clean there are preventative sprays to coat the terminals. Vasealine works pretty good for that too.
Having RV issues? Connect with others who have been in your shoes.24,318 PostsLatest Activity: Sep 14, 2025
