2ndhom
Aug 07, 2013Explorer
Disconnecting Cleaning Bat Cables & Terminals
I'm seeing a white powder at the bottom of the battery tray as well as some around the cable/terminals.
I've taken pictures of the ( 4 ) 6 volts and ( 2 ) 12 volts so I know where to return the cables/wires to their origunal location. I'm sure I should turn off the main switches. I see a couple of smaller wires connected to the terminals .... could those be from the roof solar? If so I should probably tape them. What additional procedure should I go thru or things to look for. Oh, I have also noticed the 6 volt bats don't stay charged as long as they used to ..... may need replacing?
