Naio's avatar
Naio
Explorer II
Oct 01, 2019
Cleaning electronic circuitry?
A year ago my van was contaminated with some kind of super allergen. I'm not sure if it was ultra fine fiberglass or what. But it had me using a month's worth of allergy meds each night that I spent in the van.
I cleaned the van itself out thoroughly, but I have a bunch of items that were in the van that I haven't cleaned.
And the ones that I don't know how to clean are the electronic items with internal fans. I can't have those fans blowing allergens all around my van. Inverters, giant battery charger, etcetera.
If I open up their cases, is it ok to wipe everything down with a damp paper towel? Will I destroy stuff?
If water is unacceptable, is there something else I can do so that the contaminants will stick to the paper towel? I don't want to just dry dust them, because then the stuff will go up in the air.
Would one of those high-powered vacuums you put quarters in at the gas station be a better choice?
Of course these are the things that are more expensive than I want to spend to replace :-).
Thanks very much folks, as always!
  • Also, use a common home vacuum that has a good filter, and a small brush to loosen stuff and in corners. Most have plenty of suction for what you need, especially if you loosen everything with the brush.
  • Use the 97% alcohol rather than the common rubbing alcohol which contains lots of water. The 97% drys better, and leaves no residue. And is harmless to most electronics, but do watch out for printed id or instructions, as the 97% will wipe most of them.
  • Canned air blasted with strong vacuum running near the object. Water is last resort. Alcohol would be preferable to water.
