Naio's avatar
Naio
Explorer II
Oct 01, 2019
Cleaning electronic circuitry?
A year ago my van was contaminated with some kind of super allergen. I'm not sure if it was ultra fine fiberglass or what. But it had me using a month's worth of allergy meds each night that I spent in the van.
I cleaned the van itself out thoroughly, but I have a bunch of items that were in the van that I haven't cleaned.
And the ones that I don't know how to clean are the electronic items with internal fans. I can't have those fans blowing allergens all around my van. Inverters, giant battery charger, etcetera.
If I open up their cases, is it ok to wipe everything down with a damp paper towel? Will I destroy stuff?
If water is unacceptable, is there something else I can do so that the contaminants will stick to the paper towel? I don't want to just dry dust them, because then the stuff will go up in the air.
Would one of those high-powered vacuums you put quarters in at the gas station be a better choice?
Of course these are the things that are more expensive than I want to spend to replace :-).
Thanks very much folks, as always!
  • Also, use a common home vacuum that has a good filter, and a small brush to loosen stuff and in corners. Most have plenty of suction for what you need, especially if you loosen everything with the brush.
  • Use the 97% alcohol rather than the common rubbing alcohol which contains lots of water. The 97% drys better, and leaves no residue. And is harmless to most electronics, but do watch out for printed id or instructions, as the 97% will wipe most of them.
  • Canned air blasted with strong vacuum running near the object. Water is last resort. Alcohol would be preferable to water.
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 26, 2025
