1fanman's avatar
1fanman
Cleaning Holding Tank Sensors
Greetings fellow Rv'ers, 1Fanman here with a question, can one of you tell me how to clean my holding tank sensors, I have used every available product and haven,t had any luck, sometimes my grey tank will show everything from empty to half full, etc after I drain it and the black tank is the same. Any advise would be appreciated. Thanks and smooth roads to each. 1Fanman.
    As mentioned already I use the Geo method I also installed the Seelevel II system. If your thru tank sensors are gunked up, try this.
    1. On the morning of departure do a complete dump & flush.
    2. Add 10-15 gallons of water to the black tank. At the camp store or the first convenience store seen purchase 4 or 5 bags of ice.
    3. Drop them on the pavement to break the ice up.
    4. Dump the ice down the john.
    5. Drive away. At your destination dump again. The black tank should read correct.
    For the gray tank 10- 50 gal a quarter bottle of dawn. Dump at your destination. This method not as quite as successful as the ice.
  • I usually put a couple bags of ice and some water  in my toilet tank just before heading to my next stop and let it slosh around seems to do a good job
  • I used to worry about cleaning out the black tank many years ago. Then one day I just realized it's a poop tank and it will never be clean so why bother. After many more y4ears with the same tank I can say that the sensors seem to have the same amount of erroneous readings as when I tried to clean it. Also I don[t use chemicals and do not have any odor problems. That being said I always found this guy on youtube to be interesting as he debunks many black tank beliefs or myths.
    Link
  • Close the tank. 5 gallon bucket. Fill it a. Outlet time and pour it in the toilet. Then dunno the tank in the septic. Just happened to me last week.
  •  Close tanks. Fill a 5 gallon bucket. Pour into the black holding tank. Open black tank to septic. Fill again. Dump bucket in toilet. One more time. It just happened to me last week not works
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
