Gdetrailer wrote:
ford truck guy wrote:
afidel wrote:
Magic eraser mop heads worked well for us to clean the awning
Yup, this is what I have found to be the easiest - -
Magic eraser head
Just be aware that just because Magic Erasers feel and act like a soft foam, they ARE an abrasive! Granted, a mild abrasive, but still can damage surfaces and material. Use with caution and care.
One should note that A&E does mention to not use abrasives..
All about Magic Eraser HERE
"Melamine foam is a porous material, which acts something like very fine sandpaper to gently remove stains. Though it feels soft on the outside, each eraser is actually uniquely abrasive and uses small air pockets in the material to lift stains when damp.
Areas to Avoid
Avoid using a Magic Eraser on polished, delicate, or easily scratched surfaces because it may end up removing the exterior finish or causing potential damage to the outer surface. Try a test patch on a less noticeable area before going to town on a larger spot.
Although versatile, you should steer clear of your car, stainless steel, glossy walls and wood, among other surfaces, when using your Magic Eraser."
Totally agree... There is NO ELBOW GREASE with these... just slightly swipe across......
I found that out about 10-15 years ago on another awning... I used a small hand held pad and really put my weight into it !
