Muddydogs
Apr 03, 2015Explorer
What are you guys using to crimp battery cable lugs? Keep in mind I will be laying on my back under the trailer. I'm thinking I will be shortening up a few wires as the bus bar will be at least 2 feet closer then the battery's are. For past lug crimping I have used a pair of long handled channel locks (water pump pliers for you farmers that run irrigation).
I was under the trailer today installing an electric tounge jack and replacing the temp wire off the solar controller and I have to say the wires could use some rerouting and tucking up. If I ever hook a stob or bush I will have a problem.
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 20, 2026
