austinjenna's avatar
austinjenna
Clear QAM DVR recomendations
I recently cut out cable at my house and just have internet service. I noticed I still get about 80 channels on the tv after doing a channel scan because of Clear QAM in the cable. Can anyone recommend a good clear QAM dvr with channel guide so I can record some shows?
  • The requirement to rebroadcast local stations in the clear over cable was repealed by Obama's FCC. All content even free basic channels like pbs or public access can be encrypted now by choice of the provider. Clear qam is dead.
    Ref Fcc 12 126
  • If you do a search for "PVR" on Amazon you get several listings. Here are two that have a QAM tuner:
    https://www.amazon.com/BlazeVideo-Digital-Converter-Receiver-Multimedia/dp/B01IMO6OXM/ref=sr_1_5?ie=UTF8&qid=1489405985&sr=8-5&keywords=pvr
    https://www.amazon.com/Edal-Receiver-Converter-Recording-Composite/dp/B01LYL35SP/ref=sr_1_12?ie=UTF8&qid=1489406121&sr=8-12&keywords=pvr
    These have a single tuner that will receive digital OTA and ClearQAM. With the addition of a USB hard drive they can be used as a PVR.
    I have an iView and Mediasonic brands which are basically the same. Hopefully the software has improved in recent models because mine are a bit quirky. Once you figure them out they work quite well and the video is excellent. Total cost will be less than $100 for the box and a 1TB hard drive.
    Just a heads up, many cable companies are dropping ClearQAM and encrypting all channels
  • I am not breaking any laws. I also have a TIVO OTA for those channels and I sleep just fine.
    When you connect a cable directly to most modern TVs, you can get the broadcast channels in HD without a set top box. And in doing this, you are not breaking any laws. This is perfectly legal.
    The technology behind this is called ClearQAM. QAM is a modulation scheme that allows the transmission of digital TV channels on an analog RF cable. Because of a number of rules and regulations, cable televesion companies are required to provide access to the broadcast channels in the clear – thus the name ClearQAM
  • RoyB's avatar
    RoyB
    Explorer II
    Getting something for nothing would be considered fraud in my way of thinking... I would call the Cable Provider and ask if it is legal to view their cable transmission without paying for it before dumping a bunch money into a high dollar DVR and other Televison monitor equipment. I think the cable provided INTERNET signals is around the CH79 - CH82 frequency bands which the cable company should be using filters just for your Internet Signals.
    What I would do if you want to continue watching TV would be to install a good quality OTA Outside Antenna setup. We get all of the local channels here using the eight Bow-Tie Flat antenna panels mounted up on the peak of our house roof line. We are roughly 50 miles away from the Washington DC and Richmond Virginia areas and there a few other digital TV towers in some of the other somewhat close towns... There is also alot of cable TV like programs also being transmitted by these local TV stations. The live 24/7 radar transmissions are the most important ones for me...
    Google Images
    This is all public TV from the National Broadcast System which is now all transmitted in High Def Digital mode and more important is legal to view and is free to the general public... You will not be considered stealing TV from your local TV provider doing this. This should let you sleep well at night knowing you are not doing something illegal... That is what my mother would have said at any rate if she was still living...
    Just saying....
    Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
