Lynnmor's avatar
Lynnmor
Explorer II
Feb 21, 2019
Clear Valterra Waste Cap
I wanted to try the Valterra T1020-1CLR Clearview Waste Valve Cap - 3" with Capped 3/4" GHT for some time. A recent thread reminded me, so I ordered two for my trailer with two drains. This didn't work out well.
First, the stickers had to be removed so that one could actually see thru the clear cap and that was wasn't easy. Also, I might get cancer now if I use these in California.
Second, the 3/4" hose connection threads were way too tight and the caps couldn't be installed. I spent over an hour lapping them with valve grinding compound. Now they fit properly.
Third, these things only have two locks instead of the more reliable four, and they have no detent to keep them in place.
Fourth, I tried to install them and they would not go. The gaskets are super glued in place at four locations and that prevents them from being compressed enough for the locking tabs to be engaged. I dug out one gasket destroying it in the process and my spares are of a different design.
Fifth, one locking tab on each has an air bubble weakening it.
I am requesting a refund, they are totally useless.
