Lynnmor's avatar
Lynnmor
Explorer II
Feb 21, 2019
Clear Valterra Waste Cap
I wanted to try the Valterra T1020-1CLR Clearview Waste Valve Cap - 3" with Capped 3/4" GHT for some time. A recent thread reminded me, so I ordered two for my trailer with two drains. This didn't work out well.
First, the stickers had to be removed so that one could actually see thru the clear cap and that was wasn't easy. Also, I might get cancer now if I use these in California.
Second, the 3/4" hose connection threads were way too tight and the caps couldn't be installed. I spent over an hour lapping them with valve grinding compound. Now they fit properly.
Third, these things only have two locks instead of the more reliable four, and they have no detent to keep them in place.
Fourth, I tried to install them and they would not go. The gaskets are super glued in place at four locations and that prevents them from being compressed enough for the locking tabs to be engaged. I dug out one gasket destroying it in the process and my spares are of a different design.
Fifth, one locking tab on each has an air bubble weakening it.
I am requesting a refund, they are totally useless.
  • Hmmm, one wonders, why does one need a clear plastic cap?
    I suppose, one thinks that seeing if there is a surprise waiting, before removing the cap, might be a good idea.
    There is always a surprise waiting behind mine, the only question is how much. It's just a trickle, caused by motion of the coach draining the low spots in the waste lines. Probably a few ounces, but seems like a lot more once it has hit the ground.
    So I'm not sure I really get the point of having this. I mean, you're going to have to remove the cap regardless, so why not just loosen the hose cap which will at least keep the stream to a minimum of mess?
    Now, clear elbows are a thing to be loved. Wouldn't be without that.
  • Made me look. I bought one of these around Christmas but it's in the box with other TT stuff. My garden hose connection is fine, no bubbles in the two "locking" tabs. I think I saw another brand of these. Figured Valterra would be better. I was mistaken.
  • Now this is the kind of review I like to see. Clear and explanatory, you know exactly what is wrong with them. Not some generic "They didn't fit and I couldn't make them fit so I'm sending them back" nonsense.
Having RV issues? Connect with others who have been in your shoes.24,341 PostsLatest Activity: Dec 05, 2025
