jeeperdude10's avatar
jeeperdude10
Clearance/running lights on toad
Have an issue with my 2014 JEEP toad not having running lights. I have blinkers on both sides and brake lights but no 'clearance'/running lights. I have installed the 'plug and play' kit using existing lights on toad and when hooked up to another 4 pin trailer hitch everything works..but when hook up to MH all other lights work. Could this be just a fuse not installed or something simple?
The MH is a 2010 Ford E450 chasis with a 2011 Chateau MH platform.
Any and all suggestions/ideas are welcomed....
  • Thanks all who responded....yep'r it ended up being #57 fuse a 20 ampere......whew, so glad it was nothing really BIG!!!
    Was in a quandry as pig tail (hook up to rv) was originally set up for amber turning....maybe that had something to do with fuse BLOWING. Anyway, we are 'in like Flint' NOW. Yahoo!!
  • Check your plug on the MH an see if you have power to the plug. If not you could have a marker light fuse blown.
  • I think ford has a fuse for trailer marker lights.
    It should be the brown wire on the plug
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
