riltri's avatar
riltri
clicking - water heater
When I turn on our Atwood water heater to electric, the converter clicks about every 3 seconds as if it is turning on/off. The w/h is definitely 110v and the breaker is not tripped and we are plugged into 50amp power. This is the only time that the converter makes this noise. Any ideas?
  • 2oldman wrote:
    Ok, inverter or converter?
    Converter..I fixed it...thanks
    ETA: when I turn the converter breaker off, the W/H turns off
  • Water heater should not be wired through the inverter.
    What is make and model of the rig?
    Possible that low voltage occurs when turning on water heater causing inverter to switch to battery source.
Having RV issues? Connect with others who have been in your shoes.24,203 PostsLatest Activity: Feb 22, 2025
