Mike_Schriber's avatar
Apr 05, 2016
Clicking sound from engine/transmission
My Damon Daybreak with a 2006 6.8L three valve V-10 and the five speed TorqShift transmission recently started making a very strange sound...
http://youtu.be/FKVNiwRtXyY
It happens when it's cold and I just start off driving for the first time. It also happens on upshifts under a heavy load (like when going up a steep hill). I've also noticed it happening when the engine is under a heavy load going up hill and I let off the throttle dramatically.
Everything seems to be running fine other than the sound and there are no codes.
Anyone have an idea what this could be?
Thanks!
  • Sure it is not a broken exhaust manifold stud? Very common on the V-10's.
  • Cracked flex plates make all sorts of strange sounds. Worth a look.
    Richard
  • Not sure what you mean by a light click. It seems like something cycling like a relay, valve or solenoid. Could be from the transmission but I can tell. Listening while driving it sounds like it's coming from the engine, not back from the transmission.
    westend wrote:
    Has anyone looked underneath the drive train? From the video, it sounds like a "light" click. It may be from the drive shaft or torque converter/flywheel area. I would try to narrow down the location.
  • Has anyone looked underneath the drive train? From the video, it sounds like a "light" click. It may be from the drive shaft or torque converter/flywheel area. I would try to narrow down the location.
