opnspaces
Jun 27, 2019Navigator III
Glad to hear it was just soot from the incomplete combustion and not an actual fire as that would ruin a vacation pretty quickly. I've had a similar issue once but as you and others noticed I heard the weird burner and shut it off before it made a big mess.
As far as the leaking pressure valve, that can happen if you lose the air pocket at the top of the water heater tank. The fix is easy but probably best performed with the water heater cold.
From Atwood
From Suburban
From Atwood
From Suburban
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Oct 16, 2022
