mtnears's avatar
mtnears
CO Alarm issue - battery charger?
We have a 2011 Lance 850 TC, pretty much factory stock, we just purchased it has had one owner previously. As a CO / LP detector.
Had the CO detector go off when we had it in our driveway plugged into shore power. Propane was turned off at the source, power cutoff was not disabled so it was charging the battery at the time. TC was closed up (all vents and windows closed and in direct sun, but nothing was on (fridge, stove, etc). The battery compartment on this is not on a slide out tray, it is under the step to the sleeper area and has a tube vent to the outside. There is currently just one battery and it seems to be in OK shape.
I was confused as to why the alarm went off, if it was a false alarm or not. Battery charging should not put out CO directly, but it was suspicious to me since it is right next to where the sensor is.
I purchased a home CO detector with an LED display on it and placed it right next to the one that came with the unit. Had it plugged in over the weekend, same sort of scenario as described above. Both CO detectors went off. When I aired it out I could see the levels on the home detector, showed 388 which is pretty dang high.
I'm not clear if because it was all closed up and hot that the O2 levels just dropped to a point where CO was high in relation, or if there is something generating CO. Not sure how to sort this out but it sure makes me nervous if we are out camping and plugged into shore power that we are putting ourselves at risk.
Anyone have any suggestions on how to step through figuring this out?
  • Dying unit! These things have a finite life, usually 3 years.
  • Appreciate you thinking about a running vehicle. In both instances, no. It was off the truck on it's jack stands away from other vehicles or any combustion. I'm thinking about seeing if I can reproduce it pretty easily. If I can, then what I may do is try to hook up an exhaust fan in the battery compartment to see if I can force that area clean. If it still happens then at least maybe I can rule out the battery and start trying to figure out if there is something else that is outgassing....
    Just going to throw this out there. Was there perhaps a vehicle idling in the driveway, however briefly, some time before the alarm sounded?
  • Was the refrigerator on on running on propane?
    You may have a blockage in the exhaust...
    Oops. just saw everything was off.
    Sorry...
  • Not much in the way of carpet in there and I'm not aware of any cleaning but can't be totally sure.
  • Was the carpet been cleaned? Clean chemicals can cause this.
Having RV issues? Connect with others who have been in your shoes.24,345 PostsLatest Activity: Jan 05, 2026
