juano's avatar
juano
Coach battery bank not working
Hi,
Fulltimer with a wife and 2 years old baby trying to troubleshoot an electrical issue for almost a week without luck, need to be able to run furnace and the rest of the equipment as its getting really wet and cold here in the mountains of Northern California.
Got a 1995 Bounder and loving it, original 6v Interstate batteries were from 2005 so totally dead, replaced them with brand new 6v Interstate deep cycle connected in series as the original. Starter battery replaced too.
After 3 days coach batteries died.
Alternator or shore power by charger/converter not able to recharge coach battery bank. I got a big wheel Napa battery charger and recharge them to 12.8v.
If I'm running engine I've 12v power but few minutes after I shut it off I lost all 12v power after a relay click. Looks like coach battery bank is not being recognized by the system.
I already cleaned the two grounds from each bank at the chassis until I got shiny metal, nothing changed.
With the engine off if I click both battery disconnect switches I can hear a click, but maybe I should go further and check it with my meter, any guidelines of how to proceed step by step? I'll take notes and update the post as requested.
My electrical skills are not great but I've 2 multimeters available, voltimeter light, wires, and the whole day to take readings and hopefully fix this annoying issue.
Thanks you!
  • Some newer converters have reverse polarity fuses on the 12 volt output terminal area.
    12 volt distribution panel have a fuse in it from the converter on some.
    Verify 120 volt AC input to the converter. Check 120 volt AC circuit breakers.
  • wa8yxm wrote:
    "After 3 days the batteries died"
    I assume you mean the house batteries
    Bad converter is my guess. but
    Make and model of converter please
    Converters have fuses.. could be that simple
    Yes, I mean house batteries.
    I already checked my inteli 9000 converter fuses and both are fine, also input is reading 120v with 13.3v of output.
    At the same time I don't think the input it's my problem as alternator is not being able to recharge my coach battery bank neither.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
Having RV issues? Connect with others who have been in your shoes.24,327 PostsLatest Activity: Oct 25, 2025
