BudFoster37's avatar
BudFoster37
Coach Battery Cutoff Switches.
I have a 2005 Fleetwood Southwind. I pushed both cutoff switches to the off position for short-term storage but some 12v overhead lights still work. Should that happen?
  • A friend has a 98 Southwind with a PD 9100 converter. It has solar, and it is installed through the 9100's fuse panel where the three set- screw bus for positive wire is at the bottom.
    The joke is that with no shore power and batteries disconnected the 12v stuff still works for a while on solar!!! After a while it sort of keeps stuttering on and off. It is really bad for the solar controller to run loads with no battery connected
  • Maybe I misunderstood the replies. Are you saying there is power through the converter when the batteries are disconnected by the switches? Pardon me if I appear dense.
  • I'm not plugged in. Maybe a bad disconnect switch? One is labeled main and the other auxiliary; what is the difference?
  • LittleBill wrote:
    completely depends on if your plugged into power, the converter will power 12v loads while disconnecting the battery's, thats the way mine works
    X 2
  • completely depends on if your plugged into power, the converter will power 12v loads while disconnecting the battery's, thats the way mine works
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
