time2roll
Feb 19, 2015Nomad
You should not have to unplug from the generator unless you find utility power.
Do you have a meter to check the battery voltage on the terminals?
Compare with generator running and stopped.
May as well post the converter or inverter/charger brand that is supposed to be doing the charging.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
