ksg5000
Feb 19, 2015Explorer II
The generator supplies AC which powers the converter which charges your coach battery. If you have the ability to read voltage - measure the battery voltage when either the generator is running or connected to shore power - should read about 13.6 volts ... if you don't have the equipment look at the interior lights, they should brighten when hooked to shore power.
If you suspect a bad converter - look for an auto reset circuit breaker (Google it as it looks strange) near the battery - if that goes south then your converter can't charge the battery. It's also possible that the fuses on the converter itself have blown.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
