MrWizard
Feb 19, 2015Moderator
IF your batteries charge when on shore power but do not charge when the generator is running ( same power cord )
You need to check the generator voltage output, and control board
it may be too low for the converter to do in any charge output
The converter should be charging when the Onan is running
The Onan is using 12v power for the electric fuel pump
But it should not be pulling down the batteries to the dead point
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
