papa45 wrote:
bpreece: Will that cable tracker work through a floor or a wall, particularly when I'm not even sure where the wire is located?
westend: All good ideas to try next. I feel sure I know what circuit it is on. I have all the fuses identified.
ScottG: Yes, I realized that right after I posted the first note. Thanks.
Another question: Each wire leaving the 12V power panel is a different color. I presume each entire circuit is the same color. Is that a common practice for RV wiring?
This will read through wallboard and even a few inches underground for buried cable.
